hi all,
i'm new in kflop user, i have change my old printer-port board to a new kflop.
the hardware: kflop, driver microstep 4.2A leadshine m542, 2 phase stepper motor 3.5 A.
Kflop control trough channel 0 the driver setting in 4 microstep output (800 step-revolution).
the motor is connected to a 2 mm screw trough puleys: 30 tooth for motor, 60 tooth for screw.
now the problem: one motor revolution corresponds to 1mm of movement of the screw.
after setting kflop, using kmotion the movement of 1mm in kmotio corresponds to half revolution of motor then 0.5mm of movement of the screw.
i have try to change the value in the config&flash Inv Dist Per Cycle, and in step response, but the results is the same.
can anyone help me to solve problems?
thanks
p.s.:sorry for my bad englsh.
